2.5 or 5 ton truck?
53
21
South carolina
I'm building my dream truck but I don't know if I should go with the regular Deuce or M813. My priorities:
1 Parts availability
2 Required maintenance
3 Power (multifuel or NHC 250) pros/cons
4 Performance on/off road
5 SHEER AWW effect.
I want to crew cab my truck, throw some 46" or bigger on, snorkel, all the bells and whistles. This will be a daily driver and toy, I do pipe welding for most of the year but I also do disaster relief (hurricanes, floods, ect), so it needs to be insanely reliable and tough. Again this will be my dream truck so no holds barred.
Side note: I will be keeping all 3 axles on.
PS: any way to sync mid and rear axles to turn the same rate?
53
21
South carolina
Full air brakes means CDL I'm trying to avoid that if at all possible. I have VERY limited info on the 809 series, but I know my way around a Deuce. I just want to know if there's any reason why a 809 series would be better.
98G
Former SSG
4,378
GVWR is the trigger in many states for CDL. The 809 series has more or less the same GVWR as the 939s. You may want to check before considering one. I suspect if the 939s require a CDL the 809s will also. (I have NO IDEA what SC wants).
Advantages of an 809series over a deuce -
1) Power steering
2) the big Cummins
3) higher GVWR
4) everything is bigger
5) can accommodate bigger wheels and tires without losing an axle.
6) the air cleaner on the fender is really cool...
Pic of my M818 with HEMTT rims and 16.00's....
jimbo66348
Frankfort, n.y.
Any motor vehicle with a gvw of 26,001lb, needs a CDL. This is the weight stamped on the tag, not what it is registered for. Also, you need a class A CDL to pull any trailer with a gvw over 10,000lb, and if your combined truck/trailer gvw is over 26,001lb. This is for all 50 states, since the feds took over the regulations.
4XDesign
47
Blythewood, SOUTH CAROLINA
I would vote for m809 series trucks. I have 3 m35's and 2 m51 dumps as well as one m925. The dump trucks are okay empty but if you load them they almost only run in low range. I've attempted loads in high and had to stop on a hill because the truck will die to the point of choking out. One option for the CDL is a class F license it's a heavy non commercial. When I tested are used a 931 with a trailer and basically took the standard CDL test but without the pre-trip inspection. The license is kind of a gray area but it was originally created for a class A motorhome pulling a trailer. You are not allowed to do anything for profit.
99nouns
17
Ocala, FL
When did that happen?
tobyS
835
IN
"any way to sync mid and rear axles to turn the same rate?" What do you mean by that?
I like the 809 series. Buy 98G's truck and add a 939 series cab to the rear and a short bed.....wallah!!....you got that dream truck.
One good thing with the 809 series is the battery location which frees up cab space for a proper passenger seat and console.
tobyS
835
IN
Only when engaged in interstate commerce. Otherwise it doesn't apply. When not engaged in interstate commerce it defaults to whatever each individual state laws say. .
In Indiana, it's any commerce at all...doesn't have to be interstate.
53
21
South carolina
I've heard that the mid axle is geared different than the rear. That the tires fight each other on pavement.
I'm glad I don't need an CDL. I'm gonna go with either an M54A2 or M52A2 and build it from there.
About that m51 dump truck bogging down what engine was it?
98G
Former SSG
4,378
That's Indiana law. Many states mirror federal law. The federal law only kicks in once you trigger the interstate commerce clause.
Bottom line - always check with someone knowledgeable for the details of YOUR state. (Unfortunately "someone knowledgeable" usually does not include DMV employees)
98G
Former SSG
4,378
The axles are geared the same. 6.44:1
M51A2 would have been multifuel. The NH250 Cummins is a good deal more powerful, especially on low end torque. (Multifuel is cool though...)
pmramsey
190
VA
You guys rock thanks. I'll be buying multifuel bc shtf stuff like hurricanes.
One day you will discover there is an M54A1 truck powered by a Mack ENDT-673 turbo diesel. The later ones run at 220 HP, ovedrive transmission, power steering. I have been working on a cab off restoration since 2015. All it needs is new paint, trim decals, and its done. Its my last truck. Mack built these machines right. Rebuilding one only convinced me all the more.
99nouns
17
Ocala, FL
I am sorry to bring this up out of no where but we at SS try to keep as family friendly as possible, I see you are a new member, why did you need to put such a graphic nick name for your self??? Are you trying to remind us of something???
Sent from my LGMS659 using Tapatalk
