2.5 ton rockwell how much can it take?
rustystud
3,392
Woodinville, Washington
did you have lube pumps for them to run diff coolers or how was that set up?
The units have a gear pump driven by a 24volt motor with a cog belt. The oil goes to the pump, to the oil cooler which is 20" X 15" X 1.5" thick. Then drops in the differential from a 3/8" NPT fitting drilled in top.
