2.73 to 2.56 conversion?
Rmtaunton
31
Smyrna, ga
Ok a modified model 20 , as in amc originally but think ring and pinion are the same the housing is obviously different set up for yokes instead of tubes
5,073
I've re-geared a lot of things. While just a R&P might be cheaper on paper. Buying new bearings and a shim kit. Then any tools you might not have. Then the time and effort of pulling the diffs to start with. I don't see any advantage of changing the R&P over replacing the entire unit. The entire unit has to be removed out to do anything to it. Unless you're wanting a custom ratio. (Using a AMC 20 gear) Only R&P in a military vehicle I'd replace alone would be a Corp 14 bolt in a 1008/1010/1028/1031. But anyone that's been in a 14 bolt would understand why I'd say that.
Action
1,562
East Tennessee
The instructions are in the TM. Why not look to see what would be involved in a gear swap. as in, the housing needs to be spread 0.010" (.25mm).
17 pages just to install part in a clean housing.
