2 Batteries Needed Post-Roscommon 12V Conversion?
spectre6000
Broomfield, CO
I can make a case for and against in my head. Has anyone run a single battery after converting to 12V? I'm contemplating an isolated in-house battery setup, and it'd be nice to be able to use the second battery for that purpose versus having to get and locate a third. Thanks.
Warthog
227
OKC, OK
With the high compression of the 6.2L, your starter will appreciate the extra battery.
spectre6000
Broomfield, CO
That's what I was trying to suss out. I knew the civilian models were 12V all the way, but wasn't sure what the battery situation was. Thanks. I imagine a single battery would technically work so long as the battery were sufficiently powerful, but two is pretty much minimum.
Skinny
486
Portsmouth, NH
One battery would do it if it was an 8D. A sufficiently sized single battery would weigh over 100 pounds and not be easy to fit in the engine compartment. Don't reinvent the wheel, a pair of decent group 31's will set you back two bills and work great.
Keith_J
1,315
Schertz TX
Power to turn over the engine remains the same, with two in series, current is halved for the starter. The glow plug draw is the same, half of that power is dissipated on the resistor bank in the 24 volt system.
Yes, use 2 batteries which is a tad bit more efficient since the 1200 watts dissipated in the resistor bank goes away. But you have double the draw on the starter.
