- 2,809
- 6,746
- 113
- West greenwich/RI
So, in an attempt to not hijack another thread that mentioned building a log splitter using the motor from a MEP-003A.... I have a home made log splitter that I've been thinking about repowering with the 2 cyl. motor off an MEP-002A and I'm interested in seeing if any members here have any experience or input? I recall seeing a video from Sewerzeuk where he did this, but I didn't see any details on what parts he used.
I currently have a 4" x 24" cylinder with a 9hp gasoline engine and I believe I used an 11GPM 2 stage pump from Northern Hydraulics. This setup works ok, but cycle time is a bit slow, even when the pump is in high volume mode.
So, my questions for everyone are: I obviously need to either get a new pump (1800 RPM VS 3600 currently) or I need to overdrive the current pump using a jackshaft, gear drive, belt drive etc.
If I go with a new pump and direct drive I will need to adapt it to the motor. Does anyone have any suggestions on building an adapter? Did you use the MEP flywheel/flexplate and build an adapter plate to hold the pump? and did you use a love-joy type or other flexible coupler, or a spline etc?
Any ideas or pictures of pump size and motor adapter ideas would be great to see. Also wondering how much of the MEP engine controls you kept intact or did you just run the basics, just to make It run?
