Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
So in case you're wondering what the Hey these are, this is the 2 pin slave cable connector for the side of the deuce, into which I've soldered some 1/0 welding cable and some twist lock connectors. I'll be able to hook ground clamps and the stinger into each contact and do battery welding, trailside, without having to pull the batteries (basically, little additional BS). Just three easy connections.
Yeah, cost me about $55 or so to put it together, not counting solder or anything. I'd try it right now but without an easy means to recharge my batteries (truck isn't quite running), I don't want to kill the bluetops and then have to try to pull start the truck or something.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
