2 m105 a2
Rthomas
Jena,La
Do you think i could put 2 m105a2 on a trailer thats 80in between fenders and 20 ft long. I think it will fit but not sure. I know that the overall width is 83inon the m105
blybrook
Fairbanks, AK
I put one M105A2 on my 20' car hauler back in February. My hauler is 80" between fenders, 20' deck and the M105 tires were 76" outside to outside, so it was close when I went to roll it off. If you are going to load and unload with a forklift, they should fit without a problem as you can arrange them to avoid your fenders.
Another thing I did as a precaution, is to bring a section of 10" channel steel (7'6" long) to increase the width of the trailer if necessary due to the wide variations of tracking width on the M105's. Even with the parking brakes engaged, it was able to hop right out of the 10" channel, so I would recommend 14" as a minimum or utilizing the 10" with some welded plates to hold the tires better.
HTH
Bill
Rthomas
Jena,La
Do I have to pull both out at the same time. I can put one in a parkiking lot, take one home then come back and get it.
blybrook
Fairbanks, AK
That is something you will have to coordinate with the GL site in question. I recently picked up 3 trailers by making several trips back and forth. They were willing to work with me on doing it. I setup a staging yard at a friends house about 5 miles away from the GL site. That made the trips quick & I could take my time getting them from his place back to mine 20 miles out.
HTH
Bill
