(2) questions... M35 manual for d'load online? and .....
EAdams
Need to know if the manual for the M35 (mine will be a 1952 Studebaker with a 331 Continental gas engine) is available online (or through a generous member) ... AND ... what is the color of the inside of the engine compartment and engine components? Anyone have a pic of a engine they can post/send me? I plan on cleaning the engine compartment well and re-painting it (for looks and to minimize rust).
thanks in advance!!! :D
1,827
RE: (2) questions... M35 manual for d
E, the best manual in general for your truck in TM 9-8022 and its not online. Next best is the 1965 versions of the TM 9-2320-209-*** manuals. Again these are not in PDF format. You can go to the TM section and download any of the manuals starting with TM 9-2320-209 or starting with TM 9-2320-361***. All of these relate to the deuce, but not gassers.
JDToumanian
Phelan, CA
Portrayal Press has reprints of all the appropriate manuals...
http://www.portrayal.com/
They're kinda expen$ive - TM 9-8022 is $69, but that's the only source except eBay, and if it shows up on there, you'll be bidding against me 'cause I'm looking for one too! :D I'll probably break down and order it from Portrayal, but I have not even picked up the truck yet, so I have time...
Jon
cranetruck
94
Meadows of Dan, Virginia
Here is a page from the 1969 TM 9-2320-209-10. It should help in the search for the right TM.
The above '69 manual does have references to the gasoline powered units, including pictures and starting procedures. Those trucks are referred to as "early production models".
