2" receiver hitch on M37
Footloose1797
IL
Some one makes a Pintal hitch that has a ball incorporated on the lower hook. I have two of them on receivers. They appear to have the same mounting plate as the military Pintal hitch. I would think seriously about swapping one of those for the military hitch. I have seen them for sale in my local farm stores. That would allow you to keep the pintal hook as well as the ground clearance. Although for your use I would probably reinforce the rear cross member and braces.
John Mc
361
Monkton, VT
I considered one of those, but the ball was far to high off the ground for use with any of my trailers. (I have Michelin 11.00R16 tires on the truck, which accounts for some of the height, but even with stock tires, the pintle hitch is still too high.)
fasttruck
638
Mesa, AZ
Remember you can get a pintle hook that fits in the receiver if you don't have one on the truck frame. I use one to tow my M 101 with a civilian truck that has a receiver.
tobyS
840
IN
Agree with firewhenready. I purchased the humvee hitch off ebay:
Installed it a bit differently on my M152. Mounted it from behind to clear the M's "S" shaped rear cross member leading edge. Had to trim some of the hitch's gusset and shorten the pintle's castle nut to account for the thickness of the hitch's mounting plate. 4 new longer grade 8 bolts. Works perfect. Attached pictures .
Your problem thmpr will be twisting the rear frame member. You need diagonal bracing from the bottom of the receiver to each side frame (45* angle or so). Clean looking otherwise. Nice job.
