I received a new air tank from Saturn to replace one that had a hole rusted thru the bottom. I'm using this as the tank next to the frame rail. The old tank has one fitting in each end, one on the top for the T fitting and one on the bottom for the drain cock. The new tank has one fitting on each end, two on the top and two on the bottom. I figured it must fit several different applications. After much trial and error I got it installed (hours). The top where the T fitting is was not in the same same location as the old tank (it's closer to the front) and required rerouting the copper air lines...After installing and starting I built to 140 PSI on a gauge I installed in the place of the drain on the other ( inside) tank but got no reading on the dash gauge. The pressure on this gauge kept building so I shut it down. When I open the gladhand on the rear no air. The drain on the bottom of the new tank has air pressure but the T fitting on top, where the gladhand connects, has none. How can this be? The only thing I can figure is the tank must have 2 sections. I can see a ridge in the middle. The pressure relief valve on the other end of this tank never opened even as the pressure got to 160. I'm mighty unhappy right now, it looks like I have to find another tank and do this all over again...Is anyone familiar with a 2 section tank?
