2- way radios
wbread99
Montana
I take my 923A2 on road trips from time to time, out of my small town. Question: what radios do you travel with? CB? GMRS? In a pickup truck, I have experience with 10 miles on GMRS and 5 ish with CB. With a shitty 2 meter antenna. I'm pretty sure I could go 15 or 20 miles on a good. Gmrs.radio
D6T
517
Vermont
It’s 90 percent antenna and ten percent radio, as you may know.
I would invest in what the most likely choice for people whom you will be with to use.
With CB your compromise may be antenna length. You can use FM mode, even with a tone, per a recent FCC decision.
GMRS, legally, would mean everyone is a family member or you all have licenses. Equipment that can all be on the same channel width will make things much less frustrating— many of the cheaper radios are wideband only, whereas the higher-end ones are narrow or can be programmed either way. On my Kenwood units, I’ve programmed one of the function keys to toggle wide/narrow, but I think the software was edited specifically for that option. You can hear the other users if you all aren’t on the same mode, but the audio won’t be as crisp, especially at a distance.
Two meters or MURS, in my opinion, would be the best compromise. Amateur repeaters will help if you are all licensed and want to cover a larger area. Say, plan to change to a certain repeater when you reach a certain exit on the highway. MURS can be incredibly useful with a 1/4 wave antenna on the vehicle, even at legal 2W power levels.
Valor
192
Apple Valley, Ca.
Just wondering, what is MURS?
bikeman
501
Ft. Bragg, NC
I get a lot of advertisements for GMRS.
My long term will include CBs, and maybe GMRS. Right now I 'm just trying to get scanners setup.
