- 531
- 712
- 93
- Canton, PA
I purchased 20 Bolt Steel MRAP rims for my M35a2. I have a few on the truck and noticed with the 1/2" adapter plate, the tire sticks just beyond the fender a little bit. Based on the photos others have of running the 12 bolt steel MRAPS, I noticed the 12 bolt rims stick inside the front fenders. I was wondering if the offset of the 20 bolt steel wheels are different than the 12 bolt. I have my adapter plates mounted to the inside or deep dish side of the rim. I spun the front tire around and made sure it was flush against the hub and have it very tight. I only have the front right on so far, maybe my steering wheel isn't straight and it's turned a little? Or I thought maybe the offset would make a difference. Anyone that is running 20 Bolt MRAPs do you have any advice on this?
Thank you in advance.
