20 micron filters
kipman
15
Lancaster Ohio
Did not know where to post this, so here goes. I have several hundred 20 micron poly fluid filters that fit in a 9.75" housing, great for filtering wvo, motor oil, water, what ever needs filtering, 1.00 each, could see how many fit in a flat rate postal box.
kipman
15
Lancaster Ohio
one inch ID, 2.5 OD will post pics later.Filter housing, I did a yahoo shearch for 9.75 water filter, came up with several hits for the housings.
kipman
15
Lancaster Ohio
RE: filter picture
Not sure what you mean, like the filter on a deuce? These are labeled as fluid filters buy uncle sam, sent a sample to a filter manufacyure in Coleman TX, they said 20 micron and the use is up to the application.
oifvet
9
(near) Xenia, Ohio
RE: filter picture
I'm thinking that if someone had this filter on the outlet of their bulk tank (of stored, used oil), then they'll get the product filtered down enough for use as a fuel component for the duece multi-fuel?
Just need to design a spigot with the filter stage in there somewhere.
kipman
15
Lancaster Ohio
RE: filter picture
Hope some of the SS guys will chime in, does the fact that the filters are polypropylene make any difference?
oifvet
9
(near) Xenia, Ohio
RE: filter picture
Probably going to need to plumb one up to your holding tank and transfer some of that ATF through it and see how it does.
Or... pump through your filter arrangement, then into holding tank.
20 micron should give good flow, right?
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
RE: filter picture
A little heat and a pump should be fine. This looks like a good way to get close to use-able fuel from wmo.
ygmir
northern CA
RE: filter picture
seems most say less than 5 micron for fuel.......preferably 1 micron.
At least, this is the info I've gleaned.........
Henry
maddawg308
734
Front Royal, VA
RE: filter picture
Those look like the ones used to filter fresh water for household consumption. They should work for anything, but might clog up right quick.
gimpyrobb
27,785
748
Cincy Ohio
RE: filter picture
Got my rig setup Kip! They work great. I have to find where I put my 5 micron/water filters now.
