Hi all,
I have a very early USMC M998 with 3-speed transmission. In 2005, it was refitted with a 6.5L engine with the 200 amp alternator.
When I start the truck, the alternator no longer puts out any power and the smart-start box keeps cycling the glow plugs.
The problem seems intermittent. I was troubleshooting when suddenly, the problem resolved itself the first time.
As of yesterday, the problem is being persistent, and the alternator will not "start."
Question #1: Is the smart-start box continually hitting the glow plugs because it's missing a voltage signal from the alternator?
Or do I have it backwards, that the smart-start box is not sending an energize signal to the alternator?
Question #2: Can a competent auto electrical shop rebuild this unit or are parts not readily available?
Question #3: Would refitting early style 60 amp alternator be a less expensive, more DIY repair friendly option?
Can I use the existing wire harness?
What bracket do I need?
