Squirel
- 12
- 3
- Fairhope, Alabama
Okay, so I have a 2004 M1123 with a NA Meltons 6.5. It has the electronic 4 speed transmission. I have been trying to figure out why it wont go above 45 mph. It starts up instantly every time. I replaced all the glow plugs. Every single one of them was burnt up, but it still started and ran fine at idle. However under acceleration it feels like it has no power and will not go above 45. I raised it up and all the wheels spin easily and freely so the brakes are not dragging. I did all the fuel system checks. It has fresh fuel, I replaced the filters, and bled the air out of the system. I did find that the return fuel line check valve by the tank was in backward and leaking. That still didn't fix it. So yesterday I had to back it up quite a ways to get to a place where I could turn it around. It felt like it was running great. Then into drive and it felt like it had no power again. So I start thinking maybe its the transmission. It's not throwing any codes other than the standard ones. It is not in "Limp Mode"
So here is where I am...
When driving it it will shift through all the gears but only into 3 and 4 when I let off the accelerator. I am thinking that maybe the TPS is incorrectly adjusted or faulty. As soon as I "get on the gas" it kicks down. I am thinking that this is why it will only do 45 MPH.
Now the big question. Does anybody have the test equipment (TPS Block Gauge, TPS Test Cable, and Diagnostic Switch Cable) for the TPS that I could borrow? I read that there is also a training video on the TPS so a link to that would also be great. I think this might have been the problem all along and could possibly be a quick and easy fix. Anybody have any insight?
