2009 vin info thread
ARYankee
33
Benton, AR
Here you go all knowing CARNAC :)
0525 21240
04F-96771
DAAE 06-70-C-0001
Left side front bumper: CO D 114
Right side front bumper: D-15
Got it from Camp Robinson in Arkansas on 3/11/09
Once again thanks. I appreciate the info.
CARNAC
The Envelope Please.
685
Corpus Christi, TX
Organization: 1ST BN 119TH FIELD ARTILLERY SVC BTRY
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2 W/W NSN:2320000771617
Serial Number:53910587 Registration Number:4D70871 Year of Mfg:1971
Manufacturer:65909 Usage Miles: 40749
Organization: 0028
Nomenclature:TRUCK UTILITY 3/4TON Model:M1009
NSN:2320011232665 Serial Number:J4FF115875 Registration Number:NF08F6
Year of Mfg:1984 Manufacturer:93219 Contract Number:DAAE07-82-C-4060
Info available from Sep 05
Basically no info on the vehicle
Organization: 691ST QUARTERMASTER COMPANY
CALIFORNIA
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2C NSN:2320009260873
Serial Number:54012141 Registration Number:NK05GK Year of Mfg:1972
Manufacturer:65909 Usage Miles: 326450
Info Feb 01
Was suppose to be transferred to 4th Bn, 518th Training Support Regiment in Maxwell AL but doesn’t appear it made it there since it was DRMO’d in CA.
Organization: 215TH MED CO AREA SPT
Serial Number:32527392 Registration Number:4B13270 Year of Mfg:1970
Manufacturer:65909 Usage Miles: 37801
Info Mar 08
Organization: COMPANY D, 114TH AVIATION REGIMENT
ARKANSAS
Nomenclature:TRUCK CARGO 2-1/2T Model:M35A2 NSN:2320000771616
Serial Number:52521240 Registration Number:4F96771 Year of Mfg:1978
Usage Miles: 28578
Info Nov 98
crazyplowboy
Champion, Ohio
Tricky one here, hope to get some answers.
Vin on data plate: 115102
Frame #: M29514
Reg#: 41207643 or 41207G43 ?
NSN: 2320000771616
Local private party, believe truck came from FL. GL 4-23-08 according to hood
Bumper #: 28 2/ 104 AVN
Thank you
blebyu
Ringgold ga
o.k. donation made
Thanks for all you do
M35A3
[FONT=Verdana,Arial,Helvetica][SIZE=-1][SIZE=-2]W32G6J8021C002A
[/SIZE][/SIZE][/FONT]2320-01-383-2047
bought from Redstone Arsenal
[FONT=Verdana,Arial,Helvetica][SIZE=-1]TRUCK,CARGO [SIZE=-2]
DTID:W32G6J8021C002A
Manf: U S ARMY TANK AUTOMOTIVE COMMAND AMSTA-IM-MM U.S
Part#: 8750343
copied and pasted from GL
bumper numbers pass side[/SIZE][/SIZE][/FONT] FL-NG-1BDE-53 BDE driver side C 25
CARNAC
685
Corpus Christi, TX
o.k. donation made
M35A3
[FONT=Verdana,Arial,Helvetica][SIZE=-1][SIZE=-2]W32G6J8021C002A[/SIZE][/SIZE][/FONT]
2320-01-383-2047
[FONT=Verdana,Arial,Helvetica][SIZE=-1]TRUCK,CARGO [/SIZE][/FONT]
[SIZE=-1][SIZE=-1][FONT=Verdana,Arial,Helvetica]DTID:W32G6J8021C002A [/FONT][/SIZE]
[SIZE=-1][FONT=Verdana,Arial,Helvetica]Manf: U S ARMY TANK AUTOMOTIVE COMMAND AMSTA-IM-MM U.S [/FONT][/SIZE]
[SIZE=-1][FONT=Verdana,Arial,Helvetica]Part#: 8750343 [/FONT][/SIZE]
[SIZE=-1][FONT=Verdana,Arial,Helvetica]copied and pasted from GL[/FONT][/SIZE]
[SIZE=-1][FONT=Verdana,Arial,Helvetica]bumper numbers pass side[/FONT][/SIZE][/SIZE] FL-NG-1BDE-53 BDE driver side C 25
What you provided is the Defense Turn In Document information. It is of no value looking up the vehicle. You must have the serial number and if possible the registration number for me to get the specific vehicle information.
I do know the unit that turned this vehicle into DRMO was B Battery, 2nd Battalion, 116th Field Artillery of the Florida National Guard out of Dade City.
Warthog
240
OKC, OK
M35A2 w/w
a. 0539 13728
b. none
c. none
d. San Antonio
e. Painted over
Thanks,
Warthog
319
Lieutenant
3,347
58
Michigan
Here comes everything from last night:
Organization: 1ST BN 119TH FIELD ARTILLERY BTRY A
Serial Number:32522391 Registration Number:4K04569 Year of Mfg:1969
Manufacturer:65909 Usage Miles: 12316
Info Mar 01
No indications it went to the 464th QM Co unless they were the ones that disposed of it.
Carnac,
Im going to repaint the organization numbers on the bumper, which would be correct:
Passenger side: 1-119F Driver side: A XX
or,
Passenger side: 1F119 Driver side: A XX
or something else?
Can "FA" be used instead of just "F"
CARNAC
685
Corpus Christi, TX
Carnac,
or,
or something else?
1-119FA but their division or separate brigade would also be listed on there suchas as
28th ID
1-110IN or 28ID 1-110IN seen it both ways. A google search should help find who their division level is or some of the guys on here from that area will know. You could also contact the unit itself and ask. Lot of options. I know I would feel flattered to have my former bumper numbers on a deuce now that they are just about all out of the system and will be a Army vehicle of the past.
CARNAC
685
Corpus Christi, TX
Frame #: M29514
NSN: 2320000771616
Thank you
The bumper numbers are for the 28th Infantry Division PA Army National guard. 2nd Bn, 104th Aviation. The truck is an old gasser that's been converted to the M35A2 standard I believe.
In the database the M was dropped but the M is correct and denotes it's history as a gasser. They also played with the data plates since it is not listed under the NSN you show. The registration numbers you provide are incorrect and not even close to what the army uses. the data plate vin is not in the system and is also worthless. Not belittling you. I am belittling the person who monkeyed with your vin plates prior to you purchasing the vehicle.
So yes the bumper # you have could be correct and the vehicle wasn't properly transferred in the database or the unit may have changed designations.
Here's what I found:
Organization:1ST SQUADRON, 104TH CAVALRY REGIMENT Location:PHILADELPHIA
PENNSYLVANIA
Nomenclature:
M35 NSN:
2320008358463 Serial Number:
29514 Registration Number:
4C1461 Year of Mfg:
1953 Usage Miles: 36628
Info Mar 83 when it was being received at the 1-104th.
CARNAC
685
Corpus Christi, TX
M35A2 w/w
a. 0539 13728
b. none
c. none
d. San Antonio
e. Painted over
Thanks,
Warthog
Organization:HHC, 36TH INFANTRY DIVISION Location:AUSTIN
TEXAS
Nomenclature:
M35A2 W/W NSN:
2320000771617 Serial Number:
53913728 Registration Number:
4M38471 Year of Mfg:
1971 Manufacturer:
65909 Usage Miles: 46341
Info Feb 08
yeager1
Colorado
CARNAC,
Truck is from Camp Dodge IA NG.
VIN is listed as 0539-3804
Unfortunately I don't have more information. Hope you can do something with this and Thanks in advance.
319
Lieutenant
3,347
58
Michigan
28th ID
I'll do some more research and make sure I get it correct.
Thanks!!
cbvet
20
Northwest (Knox) Indiana
OH MIGHTY CARNAC!
Please see what you can find.
A: NL083K C325-10247
B: NL083K (on glove box door)
C: 2320000508913
D: Private Sale - (May have come from John Winslow)
E: There was a P525 as I recall
Also: Contract#DAAE07-79-D-5015
A: 04N-93271-0525-24551
B: 04N-93271 (inside pass door)
C: Stock #23200771616
D: Private sale, 2005, Minnesota
E: None
Also: Contract #DAAE 06-70-C-0001
Thanks very much! And I'll gladly send another donation.
Eric
CBVET
ohnuts
indianapolis in
Hello Carnac
Happy to have you back.
Purchased M185A3 third week of this month from Camp Dodge, Johnston IA
s/n 053010002
dtid W90QP882901009B
Iinstrument Repair
34-2-434-BSB (LEFT FRONT BUMPER)
B231 (RIGHT FRONT BUMPER)
B331 (REAR BUMPER)
KsM715
142
St George Ks
Sir, thank you for any info you can find on this truck
A. 11594
B. ?
C. 23209216365
D. Pottawatomie county kansas surplus auction
E. ?
marchplumber
3,171
Peoria, Illinois
CARNAC, thank you for you effort on behalf of myself, and the MANY others that have gained from your research! I personally would have NO clue on how to acquire the information that you share with us so readily!! THANKS!:-D That said, this is the information that I found on the "Raven Deuce"
A. VIN 012512692
B. Reg#.....?
C. NSN 232000771617
D. Purchased from Army 6X6 03/07/2009
E. Bumper #/letters Front Right G400 Front Left 147ATS
F. Toolee Army Depot in 10/89 CARC 10/89
G. Has tag near glove box with USA printed and below that 4G6639
I would greatly appreciate any information that you could share. Again, THANK YOU!!:grin:
CARNAC
685
Corpus Christi, TX
CARNAC,
OK, I give, is it a spaceship, aircraft carrier, or deuce with winch, or without winch, a WWII jeep.
usmarines72
California
Hello, this is for a M35A2
a. Serial Number (VIN number): 0125-27147
b. Registration Number: 4J-3010
c. NSN without dashes- sorry can't make it out, dataplate is rubbed/faded real bad
d. Where you bought it- privately 2008
e. Bumper numbers if you can legibly read them- rattled can over
