- 7,519
- 10,543
- 113
- Papalote, TX
If as you stated earlier you are seeing 4.8 ohms at the J1 TCM connector lower case k and g then the PCS coil is probably OK.
If you do see 4.8 ohms at k and g then it is time to pull the TCM, box and all and put it on the bench and open it up and check for moisture.
If everything is dry then check for continuity between the J1 connector on the box to the connector to the TCM itself, lower case k to C15 and lower case g and D16 if all that checks out then I would substitute the TCM and see if the code 73 is still set.
