- 152
- 26
- 28
- Franklin, TN
https://policeandtacticalsupply.com/shop-1/ols/products/2012-reconcraft-21-riverine-rsdv
Located in Franklin, TN. $74,500
Available is a 21’ 2012 Reconcraft Riverine RSDV. Boat was recently refurbished and re-powered with new 200HP Mercury SportJet Optimax.
Originally designed for the U.S. Border Patrol's requirements for a shallow draft vessel (< 4" water) capable of operating in shallow rivers with hidden obstructions and heavy vegetation, the Riverine Shallow Draft Vessel (RSDV) is available in diesel and gasoline configurations. This model is ideal for patrols requiring tight maneuvering at high-speeds. Specifications Length Overall 21' (6.4m) Beam 8' (2.44m) Draft 11" (28cm) static - 4" (10cm) on plane Deadrise 5 degrees (stem) HP Range 200 - 350 (149 - 261 KW)* Boat Weight ~3300 lbs (~1500 kg) Max Payload 2000 lbs (910 kg)** Recommended Crew 2 + 3 extra Operating Range 150 NM (275 km) Fuel Capacity 50 gallons
Currently has 48 engine hours. This RSDV is in very good condition and runs perfect.
21' RSDV w/200HP Mercury SportJet Optimax,
Includes 3/16" Hull, 1/8" Sides, Lever Controls, Intake Grate, 55 gallon (208 litre) Fuel Tank, Circuit Breakers, Nav Lights, Bilge Pump, Tie-Down Rails, Bench Seat, Fire Extinguisher
Options included on the RSDV:
HullShield™ Bottom Protection System
1/4" Aluminum Bottom Upgrade, 3/16" Aluminum Gunnel Upgrade
Black Rubber Rub Rail
Full Hard-Top
Flush Mount Flat Top Cleat Package (Qty 6-6", Qty 1-8”)
3M SafetyWalk™ Deck Tread
Bow Storage Locker
Dual Battery Upgrade with 4 Position Switch
Battery Charger & Monitor-Newmar PT14W
Bilge Pump Upgrade (1 auto/1 manual; 2450 GPH)
Engine Compartment Sound Isolation-Sounddown
12V Accessory Plug (Qty 2)
Compass-Illuminated
Interior and Exterior Marine Paint
Adjustable Coxswain Seat w/ Folding Bolster
Lights-High Itensity LED Lighting Package (Qty 6) - 360 Degree Coverage
Searchlight-ACR RCL-100-12D w/ Console Mounted Control Pad
Dimmable Console Switch (0-100%) for Illuminated Console Displays
GPS, Chartplotter, & Depthsounder - GARMIN 4212 - 12" Display
VHF Radio-Standard Horizon GX2000
Long Range Antenna Upgrade - 4' Fiberglass Rod
Full Hard-Top
Bow Storage Locker
Compass-Illuminated
