2016 Ga Military Vehicle Rally buy/sell/trade thread
Austringer
35
Atlanta, Ga
Also need 2 of the M35/M54 fuel tank gaskets for the strainer. It's the following gasket... If you have one or two, or will have some for sale at the rally, please PM and let me know.
5,144
Still have the HMMWV, might consider trades if anyone is interested. (Sorry no CUCV's) Also would like to find a M35A2 minus the axles/suspension/t-case/bed.
5,144
That would mean I'm still needing the cab/controls/engine/transmission/radiator/fuel tank/exhaust/exc at the very least. (Don't really need the hood or fenders, but brushguard and headlights would be nice)
2,498
You know exactly where the whole shebang is located!:-D Bring $3K and come get it:mrgreen:
Trailboss
140
Norwood LA
Got a bunch of 14.00x20 Goodyear tires mounted on 5-ton rims, probably 75% or better tread - $175 delivered to the rally.
Some Goodyear G177 11.00x20 tires mounted on 5-ton rims, 80% or better tread - $150 each delivered to the rally.
11.00x20 NDT tires mounted on 5-ton rims, 60-80% tread - $75 delivered to the rally
I won't bring any of the tires unless someone commits to purchase, and I only have a 16' trailer, so can't bring all of them even if someone wants them.
Surgical sink - it looks like it was set up and transported often, but was never actually put in use. I will supply hot water with 120v or 240v single phase power, and will still control water flow without power if the water can is placed above the sink. Come with manual, all parts, bag of critical spares and a huge transport case (which is probably worth $75 by itself). I bought a lot of 2 and will be installing one for my camper setup. - $175
Still have NOS in the crate medium Hunter tow bars with all pins, chain clamps, 3/4 and 1" feet. Brought 4 last year and didn't sell any, so will only bring one if someone commits to purchase. - $450
LOOKING FOR good condition CUCV tires LT235/85-R16, don't need the rim.
5,144
I'd really feel bad about hacking up a complete one. That's why I was hoping someone had already started gutting one for a mud truck and "bobber kit".
TaylorTradingCo
68
Ringgold, GA
I have several "cabs", where I cut the frame off just behind the cab and kept the front end less the suspension and axle, just for parts.
Derek Taylor
Trailboss
140
Norwood LA
To continue my post #209 ...
(By the way, Taylor Trading Co has medium tow bars in the crate cheaper than me - he must have got better deal than me!.:???: Buy his first, then PM me :-D)
Let me know if you want me to bring any of the items since if I don't hear any interest I may not bring some of them.
Rope pulleys, single - $45, double - $60
Front or rear tow shackles w/1" pins - $5 each - SOLD
Fuel or water can mounting brackets, have minor paint flake or rust - SOLD
Take-off M939 series air dryers (I've noticed some slight variations in fitting locations, but should work in all trucks) - $45
M939 series muffler shield (if you want to lengthen the shield on your muffler/stack to prevent accidental burns) - $50
Two new or NOS never mounted Michelin 14.00x20 XZL tires still have paper tag on tread - $350 each
One Michelin 14.00x20 XZL tire mounted on 5-ton rim in 99% condition. The mold seam and rubber tips are still evident on the tread. - $300
Also willing to trade any of the above for an excellent condition Yanmar 3KW diesel generator, or VG/EX condition 235/85R16 (same as CUCV) tires
1crook
Bethlehem, GA
NOS Grote Military LED Turn Signal Light Pair without the bucket NSN 6220-01-550-1399 M35A2, HMMWV. Also fits other popular MV’s. Only fits in the aluminum buckets. $90
New Military LED Taillights Set Tan M35A2 M923 M816 M998 Omnivolt 10-34 volt without the bucket $85
New Military LED Turn signal and Taillights Set Omnivolt 10-34 volt no buckets $165
NOS Military Tow Light Set $225 (Does not include cable).
New US surplus trouble / work light for military vehicles. 35' cord. Magnetic base. $65
NOS Military Pioneer Rack w/mounting straps and hardware M35A2, etc. Fits everything but some HMMWV’s. $75
NOS Military Tire Inner Tube 11:00x20 11x20 NSN 2610-00-029-0563 $20 each
NOS M35A2 Brake Master Cylinder M109, M109A3, M35, M35A1, M342 M49A2C M44 Deuce $40 each
NOS Military IR lights for M35A2 M35A3 M1009 M1008 M927, etc. $45 a pair
NOS in the box Cargo Cover Tan for M35A2, M35A2C, M35A3, M35A3C, M35 $200
NOS Armor lights that include the IR light and headlight with mounts for $125 a set(two lights and two mounts). Please let me know if you are interested in sets of these as I will not be bringing many unless someone requests them.
NOS Air Shifter/Ratio Selector for the Caterpillar 7155 Transmission M915, M916 $100 each (Will only be bringing some of these if someone commits to buying them).
NOS Caterpillar 7155 Transmission Control Valve/Valve Body NSN 2520-01-072-9957 $300 each (Will only be bringing some of these if someone commits to buying them).
NOS Red Cross Signs (I am only bringing these if someone commits to buying them). $30 per pair
NOS M59 Oven Doors $25 each (Will only bring if someone commits to buy)
NOS LED Tan Taillight Sets w/buckets $125 per set (I only have a few of these left).
NOS Military Ammo Can Holders for the 50 cal and 20mm cans $15 each (Cans not included). These were originally intended for the HMMWV, but can be mounted to any flat surface.
NOS Military H-45 Heaters $75 each (All have some surface rust), includes stack, a fuel flow control valve, heater lid, fuel supply hose, reaming tool, stack cap with guy lines, and a gravity feed adaptor, does not include jerry can stand. (I will only bring these if someone commits to buy them).
NOS Warning Light/Dash Lenses $2 each
NOS Red Clearance Light Lenses $2 each
NOS 5 Ton Axle Boots NSN Pair Non-Zippered NSN 2530-00-421-7227 for M939, M809, and M39 series 5 Tons $30 per pair
NOS Military Troop Seat Portion, not entire assembly M35A2, M923, M925, M813 $75 each. I only have one of these left if anyone is interested.
NOS HMMWV Insulation NSN 2540-01-369-3230. I am blowing these out at $5 a piece. This would be a good way to insulate other vehicles besides a HMMWV as the pieces are cut into squares. I will be bringing several pieces of these if anyone is interested. They are really thick and might make good floor mats as well, you would just need to have a way to secure them to the floor.
New Military GI Surplus Convoy Light Kit NSN 6220-01-449-1239 w/connector. This kit was originally for the HET, M1070 and Trailer, M1000. This kit can be adapted to any 12V or 24V military vehicle. $85 Each
NOS Military M939, M809 Series 5 Ton Emergency Stop Cable NSN 2590-00-197-1739. $10 each
NOS Military Seat Belt M939 Series 5 Ton M923, M931, M925, M927, M930 etc Black. This is the seat belt for the passenger seat. $15 each
I also have a lot of loose items like pickax heads, Budd sockets for the deuce/5-ton/M-series trailer axles, the long breaker bar that goes with them and a lot of assorted tools like hacksaws, hammers, pipe wrenches, pry bars and other stuff. It’s all new(some items have surface rust) and I’m going to be blowing them out at cheap prices to make more room in my shrinking warehouse.
Also have a new M105A3 trailer spare tire kit, in the crate. Mount, wheel, tire, etc. $200 If anyone is interested in this item, they must prepay for this item. It is heavy and takes up a lot of trailer space.
M35A2/M35A3 NOS Cargo Cover Kits in Tan (includes dropside bows, dropside corners, fiberglass staves, mounting hardware, new one piece vinyl cover). $450 each kit. I have five of these left.
Please PM me if you are interested in any of the larger items so that I can make sure to bring them.
Thank you,
Dawn
Capt.Marion
15
Atlanta, GA
I'm looking for the following:
1. a known working M-series 60A 28V alternator for an M35A2. Just the plain-jane Prestolite AMA-5104UT or equivalent. -- DONE
2. tire inflator gauge, one of the Milton-style ones with the double-ended chuck for filling dual-mounted tires on the big trucks. I don't care if it has the whole hose and glad-hand connector with it or not. I want to say that Drew Ward or someone in his camp had a bunch of these last year, but I figure I'll check if anyone with an eye on this thread has some they're bringing.
3. a set of 6 new or NOS injector nozzles for the LDT-465-1C Multifuel. NSN 2910-01-214-2643, P/N 12354295.
EDIT: Got an alternator reserved. Still looking for inflator gauge or injector nozzles.
Austringer
35
Atlanta, Ga
Looking for someone who can remove 4 run flat 1400x20 tires from lock ring rims without beating them with a hammer. Does someone have a press that could get them off? Each tire is about 300 lbs I figure. let's just say, I don't let them fall on their side or it's off to get the neighbor or have to bring out the engine hoist to pick it back up.
sandcobra164
323
Leesburg, GA
I am looking for an A/C compressor bracket for an NHC 250 and a tensioner depending on price. I am looking for other stuff as well depending on budget available. My injection pump decided to fail on my M923 so that ate some of my "spending money" rather quickly this year but I still remain committed to the purchases I have agreed to. They are
Headache Rack - Clinto
Pioneer Tool Rack - ClintoGF
Ya'll are good and I will see you there.
