2019 Findlay Oh, Armed forces day show May 17-19 Sell+ swap
MWMULES
352
DESOTO, KANSAS
I don't have a clue on what I still have at the Dayton BeefCo hub except for some Tan NOS cargo covers for the USMC 7T truck, they also make a great goose neck trailer tarp. usmc cover.jpg I have a spare used frame set for the 16 X16 tents 16 frame.pngand NOS up rights for the MGPT tents mgptpoles.jpg,
mfkoven.jpgone new field oven, w/o burner talloven.jpg I have some NOS in the box 5 gal CAMBRO liquid containers $70cammy.jpg
& Cambro "CamCarrier" with food pans $100 Cambro-Camcarrier-Side-Loader-Food-Carrier-200MPC-_1.jpg cam2000.jpg
If you want any of these PM me, as only going if there is a buyer as they take up mucho space.
I will bring a few New still in cardboard box NOS deep 50 cal cans with foam padding inside. $12ea PA60F.jpg casealu.jpg
I also have, in like new condition the para foil for the CQ-10B "Snow Goose" drone, it is rated for a 1400lb pay load! In flyable at your risk condition $150
There looks like there will be plenty of room in the BeefCo bunk house for those need a place to sleep.
skytroop232
Galena/ Ohio
IMG_6706.jpgIMG_6708.jpgIMG_6709.jpgIMG_6707.jpgPicked up a WWII Era Wood TNT Boxes, these are perfect Man Cave items, with labeled tops, all the corners are fingerjointed.
Selling for $25 each or 2 for $45. Also have 1975 dated wood
Ammo Crates with latches and Rope handles for $20 each. TNT boxes without lids for $15 each
I will have plenty with me. I am right next to Kip's spot. IMG_6923.jpgTNT Boxes.jpg
gottaluvit
Hello, I havn't been on the site much lately. New job takes a lot more of my free time. I do have the Findlay Show weekend off however. Didn't make it last year because of the rain. Hopefully not a washout this year. I have some larger items to bring.
One barely used extra set of M929/M930 troop seats ($100 set), three extra steel bows with corners (two have the fiberglass vertical pieces attached ($35 each) and one has only one attached and a broken one($25)), passenger side of thesteel upright posts ($50)(that are all connected together-please forgive my not knowing proper names for these parts). Four of the five steel posts that were attached together with the horizontal fiberglass board on the driver's side also survived the tree, to include the rearmost one that the strap attaches to; they need the tin top with the attachment holes straightened up some ($10 each). I also will have the tri-color cargo cover that nearly survived a 3' diameter 80' tall locust tree falling on my dump truck with only a 20-30" (or so) tear in it, as well as two other previous mice damage repairs ($100). I also already have loaded up, one more NOS complete tri-color cover set (with troop seats) for the M929/M930 trucks ($350). The cover in the new complete set has no mice damage or tears. I am not sure if the cover could be used on the older M800 series trucks. These would be pretty tall with the taller headache rack on the M939 series dump trucks vs. the older 5-ton trucks. The bows need assembled and the hardware is present in the complete kit.
I also have one set of used bows for an LMTV or M1082 trailer($200). Edit: the ten horizontal tubes are all of the longer size (meaning five need cut down to the shorter length) and only one tube has the pushbutton latches. The other 9 are just slide-in tubes. I will include a new strap that is made to hold the assembly together on the type that don't have the pushbutton latches.
NOS M105, M200 trailer tongue jacks, only two available ($125 each). Edit: only bringing one if none are requested
I will bring a few of each of NOS M939 series mufflers($90 each), both sides of the cab mounted fenders NOS ($90 each), and passenger side hood mounted fenders NOS ($225 each). Boxes for the cab mounted fenders are rough and the hood mounted ones are in plastic, not boxes. Boxed fenders and mufflers are in new condition. The bagged fenders may have a scuff or two but no dents or dings. Edit: The hood mounted fenders do not have bags. A couple have small bends to the front mounting plate that is underneath, but could be straightened easily. I will be bringing four of the hood mounted fenders.
110x24" rubber mat/belting NOS in rolls ($15/roll).
15' long 3/4" diameter T-80 alloy single leg chains with hook on one end for hooking to itself (or another chain) and a pear ring on the other end. These look great on the front or rear of a larger MV, and have a 22,500 WLL so they shouldn't break too easily. Each chain has it's own serial number NOS ($150 each).
Large tan 4' tall, 1.5' diameter polyamide (ripstop nylon), grey Teflon backed bags stuffed with all of the covers for the weaponry on the Kiowa Warrior chopper, each in it's own sewed on bag. Even the main bag has a larger cover sewed onto it so each item can be stuffed back into it's own attached bag. The other items have smaller bags but all stuffed bags stuff into the larger bag. The larger bag can be unstitched from the cover without damaging the stitching on the cover or the bag. There is a lot of use for the smaller covers such as mower covers, rototiller, etc. or just use the material to make your own cover if you have a means to sew this material. 100% waterproof material. It is a lot of material great also to make seat covers for tractors, etc. ($10 for each larger bag (and it's attached cover) stuffed with smaller bags containing a cover in each bag). I will only load new ones (and only about ten more than requested), as I have a mix of new and used ones. Any bulk requests should be made in advance and price is negotiable on larger quantities. Edit: only bringing four more than the requested amount. I think my trailer is shrinking.
M939A2 or M809 series 5-tons fuel filter separator upgrade kits with new hoses, bracket, hardware, and filter with housing. Only bringing two more than requested quantity pn: 57k0251 NOS ($100 each)
HMMWV front seat belt shoulder belt upgrade kit for non armored trucks. Has all parts including the seat frame, head cushion pads, etc. 57k0202 NOS ($55)
HMMWV rear seat belt shoulder belt upgrade kit for 4 door trucks. Missing the seat belt female latches but I believe the ones on the lap belts are the same. 57k0203 NOS ($45)
LMTV or any MV 5" black convex mirror sets w/ mounting brackets NOS ($15/set)
M939 Propeller Shaft Assembly, Front Axle to Transfer Shaft (Rockwell; not Dana). Bolt-on U-joint caps (not circlips). Fits M939, M939A1 trucks. NSN: 2520-01-127-6950 Only bringing one more than requested. NOS ($200 each)
CUCV Pewag tire chains NOS ($100/set)
M929/M930 Passenger side fuel tank protector plate mounts behind fuel tank in front of rear axles. Steel construction. OD green. Rough boxes. Bringing two. NOS ($100 each)
Tripod fuel nozzle hangers. 30" tall with three nozzle hangers one on each leg. OD green. Chains hold legs apart at proper width. NOS ($20 each)
Green vinyl Deuce or 5-ton end curtains. (One tan curtain) NOS ($15 each)
Tan 25' long 2" water hose heating blankets/sleeves. 110 volts. ($40 each)
More to follow as I dig stuff out to take.
Edit: Bringing:
One set of HEMMT brake shoes. PN: 1008757 NSN: 2530-01-287-2165 which was superseded by 2530-01-143-4342 ($50)
400 watt multi-vapor Metal Halide bulbs for light towers. MVR400/C/VBU/HO. Frosted inside. ($30 case of six)
Jbulach
2,400
Sunman Indiana
....110x24" rubber mat/belting NOS in rolls ($15/roll)....
Interested in two or three of the mats. Roughly how thick are they?
Also if you run across a couple more of the regular rectangular mirrors for the 939 im still interested.
MWMULES
352
DESOTO, KANSAS
Radio shelves and mounts
and some Green Temper Tent skin parts, end section, window sections, cheap and only loaded if there is buyer
#69 #81 #87
Postman515
46
Clayton, Illinois
Some things came up so doesn't look like Ill be making. If interested in something pm me and we can work out shipping. Thanks
We will be there in the same spot- poultry building
lots of Hmmwv Parts. Possibly Some 5 ton winches and 915 parts if there’s some interest
gimpyrobb
dumpsterlandingfromorbit!
27,787
779
Cincy Ohio
Ill probably bring some "go lights" with multiple remotes and protective poly domes. Ive got a hemtt cargo cover new in the box I'd like to get sold. M101 fiberglass racks new. Ive got cargo bows available new metal $10 each, but need to know ahead of time. I also have big ass brand new mrap air filters for $50 each.
Stan
St.Louis, Mo.
I'm planning on making the trip and I have some stuff to sell. You know I've never posted any pictures before so here goes. My goal is to post some pics and then some prices. If interested in anything send me a PM to make sure it gets on the truck. Looks to be a familiar crowd so should be a fun time.antenna mount with guard.jpgarmor light.jpgarmor light.jpgaxle clamps.jpgboarding ladder.jpgbow set.jpgbridge plate.jpgbumper shackles.jpgcamo support system.jpgdecon apparatus.jpgdecon kit.jpgfield desk.jpgground rod.jpghunter stove.jpghunter stove.jpgimmersion heater.jpgimmersion heater.jpgjerry can holders.jpgjerry can insulation.jpgjerry can stand.jpgjerry cans water.jpglight kit 2.jpg
Stan
St.Louis, Mo.
Antenna mount $40, Armor light $5, Two axle clamps $80, Boarding ladder $65, Ten uprights ten corners five bows hdwy $225, misc, clevis $5 set, Camo support system bag 12 poles 6 tops 24 stakes $140, Dcon bottle $25, Dcon kit $35, Field desk $125, Ground rod jerry can thing $25 ea, Hunter stove $350,
Stan
St.Louis, Mo.
Immersion heater $125, Jerry can holders $20, Insulated cover for jerry cans $25, Jerry can stand $20, Water containers $25, Lighting kit $120.
surplusyes
52
Maryland
Have to pass, 2 great shows Sussex and Aberdeen, need to go back to work. Thank you Ziggy and Andy for steak dinner awesome. Great talking to Tom Murray and a Happy 86 birthday to him. Fascinating hearing his stories on military vehicles.
