22.5 bud on a 5ton
ccequipment
Unionville,IN
I have a guy who is wanting to put a set of 22.5 10 hole bud semi wheels on a M813 5 ton I have. I belive I have seen it done, just wanted to double check to make sure it will work, Thanks
area52
San Bernardino CA
Pretty sure it will work, I think the lug pattern is the same dimensions and 22.5 will give you alot more tire options at least for street tires.
supermechanic
poconos, pa
More info
If you just want to do the front axel, 12r22.5 have the same height and revolutions per mile as the 11.00 20.
I had to change out the stock ndcc's when I found the front end pushing on wet roads .
Much safer now, when I turn the wheel, the truck steers.
