22.5 tires... 10 bolt hubs...5 ton stub / hub on 2 1/2 ton outers / housing?
bugwhacker
KCMO
Is this a reasonable possibility?
Modified 5 ton axle shafts for the back and 2 1/2 ton inner - 5 ton outer hybrid front.
Or something along those lines.
It seems it will make the overall axle wider and will need a custom disc brake setup.
My purpose for this is that I really want to get to a 11r22.5 tire and I have not found a rim that will fit this tire to the m35 as is.
I really wish someone would make a 8.25" steel rims for the m35.
Ideas?
