24 bolt HMMWV pilot washers
Warren Lovell
SAN DIEGO, CA
Quick question...do the 24 bolt humvee wheels need the pilot washers when bolting the halves together? My rims did not have them and when I put them back together there is lateral play. if so, do I need 24 of them?
Thanks guys
warren
TedG
MI USA
Typically not used anymore. If you do use them, you only need 3 per rim at:
12 oclock
4 oclock
8 oclock
Warren Lovell
SAN DIEGO, CA
Okay thanks! just ordered from Hummer Parts Guy. He said the exploded view of the wheel doesn't show the pilot washers, but that if there is play, it will eliminate it. he suggested the same amount as you, spaced every 8 bolts.
Thanks for the reply.
