The question is: How will a 24 volt solargizer work across 2 12 volt batteries wired in series and 2 12 volt solar cells and regulators wired individually to the 2 batteries mentioned above?
Will the pulse that the solargizer creates wipe out the charge regulators?
Do I need diodes on the charging circuits to isolate the charge regulators form the pulse?
I have some marginal mil batteries and I thought I could keep them on a solar charger continuously to charge Li-po batteries and other hobby batteries through chargers that use 12 VDC and I would just take off the batteries.
I also would like to run and inverter and charge other rechargeable batteries that I have.
I would keep the whole mess in a glass case outside so if it catches fire no biggy!
