24V equp. on a 12V veh.??
Whiterabbit
14
Bristol Va.
Is it possible to use 24V equipment on a 12 vehicle? I want to use a 24V radio setup on civ. truck or possibly a M274"mule. Don't laugh
Militoy
Mojave Desert, CA
There are plenty of other options available to you - you should be able to pick up something appropriate from an electronic surplus store. First - you need to determine how much power (in Watts) you will need to run your radio gear. Then - try a Google search for "DC-DC Converter 12 24" (or 12 to 28V) - and look for a model that converts 12V to 24V or 28V, and has at least as high a wattage rating as the equipment you are running. If you are unsuccessful in your search, you might consider using a lower-power DC-DC converter just to charge up an additional battery in series, and make your own mini-24V system on your Mule. Most radio operations are intermittant - so you may not need to provide the full output power needed by the radio directly from the converter.
m109guy
27
ON
There are some for sale cheap on ebay.
I know we are not allowed to link to auctions, but just search for "Military High Power supply DC/DC converter 12V to 24V" and you will find it. They are also located in the US.
I have 5 of these types of units, and they work great.
