2nd PTO on M916
Floridianson
2,491
Interlachen Fl.
What were you thinking of running? My M920 had the small auxiliary ports at the base of the rear controls and double pump on it when I got it.
simp5782
Feo, Fuerte y Formal
9,329
Mason, TN
I wanted to pull a dump trailer.
Just T off the exsisting line and put a shutoff on the winch control system so that you can use the existing tank and system but it wont flow to the winch but down the frame to the dump trailer instead. Should be able to do it AFTER the control for the winch so that you could use the existing control valves.
or a pony motor/pump/tank setup for the trailer itself
Lukes_deuce
123
Long Island, NY
Im not sure which 916 model you have, but the original 916 and A1 models have a second pump for aux hydraulics. From the one I looked at, the owner used those to run every trailer he had. Dump, low boy, live bottom, etc. I would check out the pump and flow rates before you try messing with the ptos. The PTOs for the Cats 7155 are hard to come by.
