max1008
- 3
- 0
- Blue Bell, PA
He is towing a M1031.What are you towing with it? I would be careful towing anything large that required 1" pins. Im no engineer but I wonder how much strength your losing by down sizing the pins?
Taylortrading is a member here. Send him a PM, maybe Goldeneagle too.Where can I find the feet for the tow bar? mine didn't come with any and was connected straight to the shackles
If you have a medium tow bar I have an extra set of 3/4" feet I can sell you. $80 shipped Priority Mail. If you plan to tow a larger much heavier truck you will need a set of 1" feet. I do not have any spare 1" feet.Where can I find the feet for the tow bar? mine didn't come with any and was connected straight to the shackles
Thank you for the referral. I am goldneagle not goldeneagleTaylortrading is a member here. Send him a PM, maybe Goldeneagle too.
I don't think a 3/4 inch pin would be safe on a M35 or larger. CUCV 's and similar size trucks it will probably work.I wasn't sure if this has been covered, but I guess its always good to have an up-to-date part number.
I haven't had a change to check the fitment on an m35 or any other models.
People seem to forget that little fact.For your consideration on pin size. The length adjustments on the medium towbar use 3/4 pins. Just sayin.
Point well made sir. I do wonder if there are different forces applied tot the pins at the shackle mount than at the tow bar extension point. I am sure an engineer could shed some light on that. There is no twisting force applied at the extension but there might be a twist at the shackle mount when you make turns with the lead vehicle.People seem to forget that little fact.
