American Patriot 1960
- 41
- 18
Hi All,
I drive a tractor trailer and need a 3-6kw DIESEL generator.
I will be using it as part of my homebrew APU system.
I'm familiar with "normal" generators and all the other parts I need for this system. What is lacking is a durable diesel generator that will last for a long time.
I have seen the MEP003 in the sound enclosier and from my limited knowledge of them I think this unit just might work.
My questions below are mostly directed at the 003 but I'm open to suggestions of other units to consider.
I understand it is military rated for 3kw but can easily put out 4kw for extended periods of time if needed. Is this correct?
How loud is the unit? I know this is a subjective question but your opinion and experience are appreciated.
Fuel consumption at idle, 50% and wide open? Or whatever info you have about it.
Oil change and air filter interval? Where can I find a reliable steady supy of filters? Filter cost?
Other routine service needed? Valve adjustment?
It would be REALLY NICE if I could hook up a remote start system so I could start/stop it from inside the truck. Is this feasible and possible?
For the electric start, 12 or 24 volt? If 24, can it be converted to 12?
What is the next higher output generator that co.es with a sound enclosure? Is it significantly physicaly larger? If so, it probably won't fit.
I know they come up frequently on that government auction site but I might prefer to get one that somebody has already gone over, serviced and will actually ship it to me. Recommendations of reliable soures for this?
Mostly it is the picking it up and shipping issue I'm worried about if I get one from the auction. Any easy ansers for that?
Thanks in advance for any and all advise!
