3 color camo
Barneyszoo
12
Riverside, CA>
Can someone please help me with a PDF file of TM for the 3 color camo patern for an 813 or M35? And are the trucks painted the same scheme? I thought I saw one posted, or on Olive Drab but can't find it now. Got the green base color on my 813 and now i'm ready for the black and brown. Thanks
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
Just go to the resources section and look in the Tech Manuals. Download to your computer. It even gives you pictures.:-D
1,172
What search terms did you try?
Did you look thought the list of TMs more than once?
rlwm211
Guilford, NY
You want TB 43-0147
or
TB43-0209
OR
TM 43-0139
The first has the patterns and the rest are regarding markings unit ids and other aspects of proper military painting.
I downloaded all of these from the resources section of the site under Technical Manuals.
There are other manuals that cover painting Viet Nam era and before paint schemes and markings.
I would go and get you the links to the downloads, but I am pretty busy and it is good practice for you to stroll through the lists. They are in alpha numeric order and not hard to navigate.
RL
hndrsonj
362
Cheyenne, WY
Keep going through the pubs you will be able to do this fast. TB-43-0209. Took me alot longer to load the reply then to find.:-D
broman78
great state of TEXAS
heads up I just contacted my Sherwin Williams industrial rep. I can get 383 green with out the carc additive for 28 bucks a gallon. Is the same paint that a lot of duck boats use for camo. Not sure what it goes for in your area, give your rep a call.
123mack
11
Jemison, AL
Do you have the stock number for the sherwin Williams 383. I tried the S-W industrial store here in Birmingham in the past, but they seemed lost, even when I gave them part numbers for green an brown CARC. I approached them using my company name incase they wouldn't sell to individuals.
rlwm211
Guilford, NY
The question I have is this: Is the paint oil based, or a latex? If it is a latex, is it simply exterior latex flat paint?
I ask because I have a formula for Valspar exterior high quality latex that is right on for the green in the three color nato green. $20 a gallon. Actually holds up well. I used it over Rustoleum risty metal primer (2 coats) I sprayed this with an HLVP gun.
RL
broman78
I don't have the item number but feel free to give the gentleman a call. was prompt with call back.
Greg Adams
903-277-4129
Curtis25
16849 ne 41st ct Citra Fl,
RL
I'm all ears?
