3 Speed Transmission Temp Gauge
dherman304
Texas, DFW
Hello all, I have a 2006 M1097R1 that is getting close to being done but I want to install a transmission temperature gauge. Has anyone done this before? I did a lot of research on the theory of where to put it on a 3L80 but no one specifically mentioned which port or connection to use. I'm thinking about adding a probe on the pickup back to the cooler??? Any help would be great!
frauhansen
512
switzerland
I would not open the oil circuit. This is only one source of failure.
I would take a threaded sensor that you can put in the oil pan. Lower the sump, weld in the nut, if necessary a protective ring around it (so that it is protected in the field) and screw in the sensor.
Then you also have the effective oil temperature in the sump and not something from outside.
Mogman
8,526
Papalote, TX
You want to monitor the temp going into the pump so the pan would be best, but that fitting on the return line on the stack is a convenient place to put a sending unit.
DREDnot
434
Phoenix, AZ
In the pan. That measures the temp of the fluid entering the transmission which is all that matters. The internal seals need to stay below 265 degrees or they harden and leak pressure and cause the clutches to slip and burn out. Per my GM tech school transmission class. Also minimizes points of failure in the system as was mentioned
dherman304
Texas, DFW
I decided to go into the pan. I need to drop it anyway to replace the trans filter. I ordered a 1/4 x 1/8 NPT bushing to tap into the pan. I plan to use a nut to secure it on the other side with JB weld all over the place. Ill post a tutorial once I get it done!
