383 in M1008...No Power!
ODdave
41
lansing michigan
Uhhh.....Propane is most certainly supplied thru a carb. Rock crawler rigs FREQUENTLY do it. It allows the engine to remain running at any angle. Just got to slightly modify the existing carb. Several companies manufacture and sell kits. I know a guy that owns a propane company and just about everything he owns is converted to propane.
LOL, Yea? hook propane up to the fuel line on your carb and give it a shot, let me know what happens. :roll:. The existing carb may be left on as a way of metering air but in NO WAY is used to introduce fuel into the engine. :cookoo:
bearboley
Circleville Ohio
I second the convertor. Its gonna be a no win for you when you put that high stall in there you gas mileage will be in the crapper.if its a 383 drivability will not be good they tend to make great power but no low ends,you gotta spin em. I think you need about a 3500-4000rpm stall.usally you need a converter that has a stall speed 2000 rpm higher than your cam makes power at
Efituned
Midland, Ga
Valve lash too snug? Cam timing? Who built the engine??
Valve lash is good. I installed a timing chain/gear set and everything was in time. I am unsure of the engine builder.
I went by the shop today and had someone look at the carb. He said everything checked out good. Fuel pressure and flow was also good. He went through the ignition timing and said it was off a few degrees, but even with that fixed it still didn't help.
He said that either the cam timing is off or the cam is to big for the engine. I am leaning towards putting a converter with higher stall. The engine seems to have great power once going down the road or when the rpms are up. Could it be that I have a bad converter or one with a lower than stock stall?
Bob H
167
That confirms the need for a higher stall.
Efituned
Midland, Ga
I will be installing a converter this weekend and I will report back.
I ordered a transmission vacuum governor (red stripe) for a gas engine and it didn't really help with the shifting. With the diesel engine the shifts were firm and on point. Now they are soft and I am in 3rd gear around 20mph. Nothing was changed on the transmission other than today with the vacuum governor. What should I do to get the shifts firm and late?
ODdave
41
lansing michigan
You ordered a vacum modulator...... The governer is under the 4 bolt cover on the rear / side of the trans.........Lighter weights mean later shifts. Put the original modulator in and change the governer.
197thhhc
15
Williamsburg, OHIO
Has anyone gone through your distributor. Are you running a big cap HEI or something else. When we build stroker engines we always have to recurve the distributor. Sounds like you may have to change to lighter advance springs to wake the engine up. What is your base timing set at and what is your total advance.
Efituned
Midland, Ga
Where can I buy one built like the original? Another reason for taking the original one out is because the vacuum nipple was sort of bent and crushed so I threw it away.
Also where can I buy different weights or a governor?
No one has been in the distributor. I bought a new one thinking the old one was the cause of the problem, but it didn't make any difference. I do have the vacuum advance line off. What should I set the base timing to? IIRC anything above 10 deg @ 700rpm starts pinging.
ODdave
41
lansing michigan
The original would be the one you took out of it... just put it back in. As far as the governer, any decent trans shop or you to a junk yard and pull one from a small block th400
Bob H
167
Dave, I thought the governor controls the 1-2 shift when the shifter is left in 1st.
The adjustable vacuum modulator can alter the shift points. The adjustment screw is inside the vacuum port.
Unless the mid 80's diesel TH400's are different than the 70's
I have mine set for a 5500 rpm shift with WOT and held in 1st. (in my car)
Barrman
2,136
Giddings, Texas
To hopefully finish out the propane discussion. Many propane kits, back 20 years ago when there were a bunch of kits out there, had a mixer that bolted somewhere under the hood. Then a hose that hooked into the air filter housing somehow. Turn of the electric gasoline fuel pump, turn on the mixer and the propane/air mixture went through the carb together.
I had such a truck way back when. Gasoline was $1.25 a gallon and propane was about $.60 per gallon.
Yes, it did go through the carb. Just not through the fuel line in the carb. Air venturi only.
Back to the question this thread is about. Go to the Edelbrock web site, down load and print the manual for the carb. I agree your problem is probably the torque converter and transmission settings as discussed already. However, follow the Edelbrock manual for how to set the carb up correctly and it will probably help a lot too.
jw4x4
Dayton, Ohio
It sure does run thru the carb. Not mixed or added to the gasoline, but in it's place. It's the diesels that can have propane injection to boost power, kinda like nitrous oxide omn a gas engine.
ODdave
41
lansing michigan
I think we may be argueing 2 different things, It may got THROUGH the carb, as in through the venturis as stated but like I said, is NOT INTRODUCED through the carb.
Like I said the carb can only be used as a air metering valve only. It dose NOT control the propane.
As for the weighted governer & modulator, they actualy work agains eachother to control shift points. you whould have to read the hydraulic flow chart to understand.
Efituned
Midland, Ga
I ordered the B&M Tork Master 2400 stall converter and new flexplate, which I will be installing tomorrow morning. The flexplate and converter I have now is a 4 pad and does not match the new 3 pad converter I ordered. Who really knows what converter is in the truck now...
I will post some pictures of the truck and engine tomorrow.
Efituned
Midland, Ga
Got the new 2400 stall converter in and man what a difference. I did a little power brake test and it will smoke the tires by barely touching the gas. I can now get the truck to idle properly in gear. Everything seems to be great with this swap, other than a small oil leak at the lower timing cover.
