- 12,195
- 329
- 0
- gainesville, ga.
Over size tires are a power/clutch KILLERIs there a more heavy duty clutch available? I work my 817 pretty hard so its only a matter of time. I'm considering swapping to the direct drive 5th gear trans to help out with the big 3-4 hole too. With 16.00' s I should still be in the 50+ mph range.
Sent from my LG-M210 using Tapatalk
You can put in a twin disk clutch, just hard to fine for the fit.
Ideally you could drop the crap trans and install a OLD 8/10 spd. spicier, it is a narrow trans with the pto on the side like what is in the truck has now, the newer ones are a flat trans and I believe the pto is on the bottom.
