- 9,582
- 228
- 63
- Dickson,TN
I usually run .30 wire in my Miller 251. It seems to do OK with all but the thinnest material and can also go 1/2" thick or more. It seems to be a good all around size. Just slow down and run cool on the thinner stuff and speed up and run hot on the thick stuff.Untrained & novice mig welder here, but I've watched the experts on TV use .24 wire on thinner sheet metals. I welded in an 18 gauge patch this weekend outdoors with my Miller 211 using .24 and didn't have any trouble with burn through, the wind was a little breezy. I set my gas output to about 30psi, which I knew was a little high but I figure it didn't hurt outdoors.
From your pics it looks as if you are running a little too cold on your tack welds (not much penetration and a humped up a lot.
