4 Hour Oil Change
Sharecropper
1,114
Paris KY
Sharecropper,
Are you thinking about the "Oil REFINER" filter by Frantz?
Also known as Toilet Paper Oil Filters
See: http://www.toiletpaperoilfilter.com
Regards
Joseph
Thanks but no, the device I remember seeing consisted of a metal box which mounted remotely, like on the side of a frame rail, and contained special filtration elements which could be replaced at certain intevals. The box had a sight glass to monitor the "color" of the oil. It removed all of the carbon and other contaminants from the engine oil and kept it looking brand new. It probably got bought off the market by the oil filter companies.
Bighorn
N/A
Lube refiner.
There are some nos fuel processors on ebay too.
Basically a stratified filter element.
There are also ways the add bypass filtration.
It is a much finer filter, down to a micron, that takes oil from the clean side of your stock filter, filters it further, sends it through a restriction and returns it to the sump.
Jozseph
New York
Sharecropper, a Puradyn Oil Filtration System?
That is the one i know has a sight glass/tube.
Regards
Joseph
CMPPhil
378
Temple, NH
Hi
Back to the original issue of removing stuck spin-on filters, having crushed one or two filters and put holes in a few. Found a trick that seems to work (somethings) take a large screw type hose clamp as close as possible to the base plate, position the screw head so you can get the head of air chisel punch on the head to unscrew. Then dial back the preasure air chisel star vibrating, give it awhile then increase the pressure. May break the first hose clamp but trick seems to work, and you do have keep repositioning the clamp so that punch hitting square to turning direction instead of denting the can.
Cheers Phil
cucvrus
10,504
Jonestown Pennsylvania
DSCF6331.jpgDSCF6332.jpgDSCF6333.jpgI have found no oil filter that this Snap-On set up could not remove. It has a 1/2' square drive on one end and a 3/8" square drive on the other end. Equal pressure and a death grip. I bought it and use it to change fuel filters on outside fuel pumps. I have used it on a few engine oil filters also. No poking holes and trying to get a pliers up in there anymore. I don't remember the price. That is quickly forgotten when the aggravation is not there anymore. Have a great day. i do remember that it was less then a carton of generic cigarettes.
