4" lift on the M1008
AlexFolino
Pittsburgh Pennsylvania
Finally got 4" front springs, 4" rear block. 4" extended shocks. Only problem im having is the u bolts i bought from a friend are u shaped and not the factory square u bolt. Not only to mention they are not long enough to go over the block and the CUCV springs. What have any of you done in this situation? Do any of you recommend an exact size and whereabouts for rear u bolts? After this i only thing i need are extended front brakes hoses. I can make the rear lines work the way they are.
