4 on the Floor
The Baron
Algonquin Illinios
Before I start, I realize that the TH400 is a bullet proof transmission and works just fine in the M1009. I was wondering has anyone made or heard of someone making the switch to a four speed manual. How'd it work out?
michigandon
82
Wake Forest, NC
Use a deuce trans, you'll get OD.
Can't be done, unless he wants to go strictly 2WD or install a divorced T-case behind it (LOTS of work).
Find a 73-87 Chebby truck with an SM465/NP205, and swipe that and the pedals crossmember, and anything else that you might even THINK that you need. Should a 99% bolt-in swap.
1,124
use a chevy NV4500 5speed, and you could gain OD, and keep your 4x4... :naner:
yupp. Best choice. Isn't cheap, but nothing worth owning is.
