UNIMOG-GUY
- 33
- 28
- Blacksburg, VA/Denver, CO
So my engine wasn't running very well so I decided to pull a couple of spark plugs to check them and make sure they weren't fouled out. Once I got the plugs out I noticed that they had antifreeze on them. So I figure that either the head has a crack/hole in it or there is a problem with the head gasket. It's a 1963 so I figure I'd have to do some work to it.
So I have pulled off and removed every bolt that I can see that could possibly be holding the head to the block. Is there some hidden bolt somewhere that I need to remove? I got the 2 allen head bolts near the distributor. I am extremely frustrated and any help would be greatly appreciated.
I have attached some pictures which will hopefully help you identify what else I need to remove.
Thank you in advance.
