419 Hydraulic Oil question
adavis
My small hydraulic tank is low (yes, I have a few leaks I need to fix) and I need to get more oil. I've looked at the lubrication manual and it calls for OE/HDO-10. I've searched online and on this site and I believe it is SAE 10W hydraulic oil. I then searched and found what appears to be an amazing deal on a 55 gallon drum of it, but before I order it I just want to make SURE that it is the correct stuff for my 419 SEE hydraulics. Here is the link to the oil I'm looking at.......
http://buysinopec.com/products/aw-1...g0DFk6NMTZuNlc8q13Gx63xE4kUYlIj7dAaAqre8P8HAQ
It sure appears to be a good deal compared to all the other SAE 10W oils I'm finding. Any reason why this would not work for my hydraulics?
Thanks.
dmetalmiki
2,026
London England
oe - hdo 10 is the same viscosity as iso 32 which is a parafin based oil. I would use it in my forktruck, not sure about your vehicle. Post back What the hydraulics actually "do" on your truck and i will dig deeper. Some hydraulic equipment manufacturers and plant users substitute iso32 with hdo10 multigrade oils. Which have good dispersant properties and additives which inhibit corrosion.
73m819
314
gainesville, ga.
As long as it HAS anti corrosion, and anti-foaming additives you should be good to go.
dmetalmiki
2,026
London England
Mineral based oils are the most common and low cost hydraulic fluids. They possess most of the characteristics important for hydraulic oils. The disadvantages of mineral (petroleum) based oils are their low fire resistance (low flash point), toxicity and very low biodegradability.
The FLU farm
1,226
The actual midwest, NM.
I've replaced the fluids in both the front and rear systems with AW 32, from NAPA.
Especially the backhoe seems to be happier with actual hydraulic fluid.
