45k wrecker rear winch worm shaft removal
MAZ537
23
EU
Hello guys,
I am trying to remove the worm shaft , I have try to hit it with a 4.5kg hammer (wood block used between shaft) but no go...I have read both TMs and they suggest different ways to remove the worm shaft :roll:
Can anyone please share his own experience ?
Also can anyone suggest a good puller for the brake drum ? I have almost ruin the threads in my Unior one!
Thanks !!!
NDT
7,511
Camp Wood/LC, TX
The second procedure is correct. The steel bearings get stuck in the aluminum bore due to dissimilar metal corrosion. It will take a lot of beating to get the worm out with both bearings stuck.
MAZ537
23
EU
Thank you NDT!
Use soft head hammer to tap worm shaft :mrgreen: Yeah sure when it was new maybe...
