Why you should always have a oil pressure gauge on your 4a032!
Installed an oil pressure gauge into the slave plug bracket after reading about oil problems with the 4a032. Never got any pressure to show on the gauge. Removed the governor oil line, no oil, removed oil filter, still no oil! wtf!?!
Pulled the cover off the oil pump and this is what I found! Engine ran fine with no odd noises for 10-15 min like this! Still need to pull 3 more heads and the cam, but no scoring anywhere yet!
