- 273
- 105
- 43
- Mico, Texas
Just finished a build for Texas A&M and found the transmission is stuck in second gear. This is a 1097 A2. When we first got it the shifter was super hard to shift, but after some WD-40 and a little work, it shifted fine. It will still shift into neutral and reverse, but when you put it into overdrive, it stays in second. I am not a transmission guy, and I realize it may also be the TCM, so hopefully someone here can help a fella out.
