erasedhammer
- 56
- 28
- Maryland
I am installing a 4l80 soon but I have a few clarifying questions before I begin.
1. Where is the TPS located? On the IP or the gas pedal?
2. If it's on the IP can the TPS be mounted on a 6.2l injector pump?
3. If it cannot or requires modifications is there a civi counterpart to the TPS that will mount directly to a 6.2 IP? Plug and play style?
4. The tutorial posted on g503 references the need for a fan cutout switch bracket and linkage ? What is this for and is it required?
5. I was thinking of using the rpm sensor that's already installed and appears to be hooked up to the diagnostics connector, but I read that it can't be used because it has the wrong revs? If I can't use that and I am attempting to use a a2 harness with the 6.2 what do you guys suggest I use to supply engine speed to the transmission. I have a tach setup using the alternator, I assume that it cannot be used either?
6. I was looking at the wiring diagram for the a2 body harness, and it is unclear what connector I would plug the engine speed output into, as I think the digram assumes I would be using the matching engine harness (I hope I won't have to?)
6.5: I assume that the tcm's 12v is drawn from one of the two batteries and then it is hooked up to a circuit breaker and then a relay so only when the ignition is on run position does the TCM recieve power? Or is the 12v connector hooked directly to the 12v tap on the alternator?
7. Exactly how much longer is the 4l80 than the 3l80? Some places I've heard an inch others Ive heard 6 inches.
8. The transmission cross member. I've heard from some people on bay that the cross member is exactly the same and can be reused for the 4l80, and all it needs is to be mounted a little bit further back on the frame. I did get the replacement mounting piece as the post on g503 said it would be good to replace it.
9. Do I need a speed sensor somewhere on the output side of the transmission or does it take that data from the speedometer sensor on the t/c?
I don't think I'm missing anything, but if anyone thinks I am, please do bring it up. If I've learned anything it's to plan each project out as much as possible to make things go as smooth as possible.
Driveshafts that I have installed:
