5/16JIC/5-AN to anything adapter
Crawdaddy
Louisiana
The last step on my generator trailer project is to hook up the 90 gallon external tank to the aux in fuel pump on my MEP-003 set. I've been having a heck of a time finding an adapter to get from the 5/16JIC fitting on the pump to any standard AN fitting size. I ultimately need to get to the 10-AN male fitting that's on the tank's dip tube.
I know 5/16JIC is effectively the same thing as 5-AN, but even getting from 5-AN to anything has been a pain. The best I've found is Earl's 991907 5-AN to 6-AN male, but then I have to find a short 5-AN hose to hook between the pump and that fitting. Does anyone have any hints on where I can find a fitting that will help me finish this project?
dstang97
30
Clover, SC
So the -10an fitting is on the tank. That sounds very big. What kind of aux tank is it? Can you get a photo of the tank?
Light in the Dark
5,195
MA
Oh, and I may have a couple left over short fuel lines left from an old 002A I used to have, which might work if you need a small hose to go from M to M.
Light in the Dark
5,195
MA
Edit: I must have tossed them out, knowing I would probably never have another air cooled unit. With that said, I DO have an 802 parts unit, which should have a short fuel line from the aux inlet, to the aux fuel pump I could part with.
jbayer
St. Aug., FL/ McGrady, NC
Why not just change the -5 90 degree fitting in the aux pump to a -6, and get a -6 hose instead of all kinds of adapters.-6 90 degree to pipe thread is a common enough fitting.
That's what I did, and I changed the -5 to straight pipe fitting on the Jerry can adapter to a -6. Still cheaper than just buying the -5 hose assy. for Aux fuel.
DieselGenAC
NJ
Parker has a bunch of JIC to NPT adapters available.
5-4 F6X-S -5 JIC female to 1/4NPT male
5 FTX-S -5 JIC male to 1/8NPT male
5-4 FTX-S -5 JIC male to 1/4NPT male
5-6 FTX-S -5 JIC male to 3/8NPT male
5 GTX-S -5 JIC male to 1/8NPT female
5-4 GTX-S -5 JIC male to 1/4NPT female
Eaton Weatherhead also has some adapters.
9100X5X4 -5 JIC fem to 1/4NPT male
C5205X5 -5 JIC male to 1/8NPT male
C5205X5X4 -5 JIC male to 1/4NPT male
C5205X5X6 -5 JIC male to 3/8NPT male
C5255X5 -5 JIC male to 1/8NPT fem
C5255X5X4 -5 JIC male to 1/4NPT fem
