Keith_J
- 1,328
- 113
- Schertz TX
I will give that a try. What is that capacitors function,and where would be a good place to look for a replacement.
The capacitor stores a charge. More importantly, it functions like a shock absorber in an automotive suspension.
The module takes alternating current, changes it to direct current through a series of diodes but it still is a bit "choppy". The capacitor smooths this out to drive the exciter circuit which provides the field current that creates the rotating magnetic field necessary to generate power.
When there isn't a load on the generator, it doesn't take a strong magnetic field strength to create 120 volts AC. So the exciter current is minimal. But when there is a maximum load on the generator, the magnetic field must be large enough to maintain 120 volts AC. So a proportional increase in exciter current is needed.
Yes, there are aftermarket brushless exciter voltage regulators on the market. But you have to know the design current of the exciter system. So you would have to measure the exciter current and voltage as it is now. If you had a variable voltage power supply, you could connect this to the exciter coil and run the generator engine, varying the power supply voltage until you got 120 volts output.
Or you could go to Allied Electronics and cross reference the big blue capacitor, probably a $6 part. then replace it. Note, this is a polarized capacitor so be sure to reinstall it correctly.
