5 Ton Air Cleaner Assy on a M35?
OD_Coyote
58
North Bend, WA
I have been thinking about putting a 5 Ton air cleaner assembly on my M35A2C. Does anybody have any insight to the pros and cons putting a 5 ton air cleaner on a deuce?
Also, if you have any pics, please post them.
Thank you,
Chris
Westech
CPL
6,104
206
cow farts, Wisconsin
well its a higher CFM filter. Should be almost a bolt in if you use the filter off a multi deuce and not the Cummins. really wont feel any more power... may help lower Temps a bit but dont bet the farm. I had a huge K&N on mine and did not feel or see a thing. But the 5 ton filter would look cool.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
Chris, I am doing that now. None of the 5ton intake hoses or tube will work. I am currently looking at duct to go from the 5" air filter housing oulet, 90* to a 4" tube, to another 90* 4" reducer to the 3.5" I have currently. The smaller fender will not allow for you to pop the lid off and pull out the filter element, you'll have to take the whole housing off to service it. I think there is one pic in the indy,ky,oh gathering thread.
maddawg308
723
Front Royal, VA
I've seen pics of some deuces in Vietnam that showed a 5-ton air cleaner mounted to the deuce fender, pulled off of wrecked M51 series 5-tons in the field. Looked cool, but I didn't think there would be much improvement in the air flow or air cleanliness.
gimpyrobb
27,785
747
Cincy Ohio
Joe, I had thought about that, but either way, I would need custom tubing. I am thinking about stuffing my fuel fired coolant heater in the stock airfilter space.
SasquatchSanta
Northern Minnesota
At one time I had concerns that the stock deuce air filter assembly was restricting my LDS-1A engine and therefore contributing to EGTs.
I installed a vacuum gauge under the steering column in place of the little warning thingy.
I can't remember how much vacuum the LDS-1A pulls but it's "very" little --- not enough to be worried about.
I figure they put the larger air filters on the 5-ton trucks so the filters would last longer in dusty conditions.
If you like the looks of the 5-ton filters by all means go ahead. I personally think they would only be in the way. Don't look for any performance increase.
SasquatchSanta
Northern Minnesota
Oh No --- Air Filter Envy!
rofl
On a more serious note ... I checked past records AND checked the gauge yesterday. It appears that I'm picking up some of that white salt dust that comes off the roads up here in the winter because the gauge now goes up to 8 pounds when I stand on the throttle. Winters up here are worse than summers dirty air wise. Anyway, a few months the gauge was reading 5 inches of merc, now it's going to 8. I'm told not to be concerned until it goes to15.
Does anyone know at what reading the original warning device under the steering column turns red?
The 5-ton filter no doubt gives a larger window of service over the stock deuce filter.
cranetruck
74
Meadows of Dan, Virginia
Yeah, Ernie, the filter "condition" indicator is actually a vacuum gauge. It turns red at about 20 inches of water (not mercury).
Edit: Normally while driving, I see about 4 to 6 inches of water on my Magnehelic gauge shown in the image below.
