5 Ton Alternator pulley shaft sheared.
hardimpact
Powder Springs, Georgia
the belt I used is an auto belt 6pk1270 I would say it was 1/2 inch too long. the picture shows the belt and the duct tape around the pulley to tighten belt. alt bypass belt.jpg
It would be a GOOD idea for EVERYBODY that has a serpentine belt engine to carry on the truck, the "short" water pump drive belt just in case the alt. shaft decides to break. Can you give the size of the short belt. ??
Andyrv6av8r
458
Spartanburg,SC
Being as I've been in your shoes with an alternator failure and my truck running hot, I just ordered 2 Dayco brands for $18 shipped for my trucks. Thanks for the information.
mkupka
Nacogdoches, Texas
I am guessing that the oe alt. is the same one used forever by the military but with a serpentine belt, the older uses had a dedicated drive belt/belts, the serpentine belt puts a LOT more load on the shaft with it driving everything, the smaller dia. shaft was fine for the dedicated drive belt BUT is to small (to much flex) to handle the load of driving everything with a single belt.
It appears that I already had separate belts for the alternator and water pump. The other belts are all intact and running just fine. There were just two small belts from the main pulley to the alternator pulley. Did the army change from a serpentine belt in one of the mid life upgrades?
74M35A2
342
Livonia, MI
From the pic, the short belt trick is spinning the water pump backwards. But, that is probably better than not spinning it at all. Multiple V belts were used on the Cummins NHC-250 engine. A single 8 rib serpentine belt is used on the Cummins 8.3L engine.
hardimpact
The belt goes around the stationary pulley(with duct tape) backwards, everything else spins in the normal direction.
