yes on the dummy shaft, as all the 5ts have the same trans input shaft. as far as the bolts for ALLl the drive lines , these are SPECIAL bolts that are used here, thay are a sholdered bolt with the sholder being 1/2", in the bolt supply houses the 1 1/4 bolt only has a 1/4 sholder, the correct bolt is a tap fit in the flang holes,thay are really a dowal bolt, thay are designed to take the sheer load between the two flanges and the nut just keep it together, if you use standard bolts even grade 8 , thay fit LOOSE in the holes, what happens is that no matter how tight you get the nut and bolt the flanges will try to move a bit because of the large sheer load, in time the bolt will stretch, if you look at a standard bolt that came from there you will see where the flanges worked on the threads, i found standard bolts when i took the 819 apart, thay were loose(the nilocks were still tight)and showed this sheer ware, it was hard to find these bolts, everybody said" oh we just use standard bolts"mainly because yhay cant find them, im getting mine from Sam Winer 330-628-4881, ask for the military parts guy-- robert. the nsn number is nsn 5306-191-1139, THERE IS NO WAY THAT NON DOWAL BOLTS CAN WITHSTAND THE HIGH, CONSTENT SHEER, OVER TIME THAY WILL LOOSEN ,because the whole unit is held together with just compresson, as thay streach the problem get worse both with the bolts and wallowing out the hole, hope this helps.
guys it mite pay you to check out your flang to flang bolts, your trans to transfer if nothing ealse, just because the military did the last fix on your truck does not mean that thay used the right bolts (my bolts had a least one coat of paint), thay would use what thay could find
