5 ton dump body
Santa
Milton, Florida
I am looking at a 5 ton 6x6 with a regular 14 foot bed. I need to convert to a dump bed for dirt. has any one done this? Is there a source for hardware for the work? Probable need a dump tailgate also. Any help would be appreciated.
simp5782
Feo, Fuerte y Formal
9,322
Mason, TN
C&C Equipment in Indiana makes the kit for about $1600 plus an arm and a leg to install it.
http://www.steelsoldiers.com/showthread.php?89237-M923-Dump-Conversion-with-8-quot-dual-stacks\
The problem with the kits is the weight it can pick up. Most of the ones they sell are 15k max lift. Plus the beds aren't that durable with their design to be used in longevity for a constant dump truck.
You can always go to a big truck junk yard and salvage what you can off older dump trucks or using fleabay.
painter paul
Fairbury, Ne
If you can find a 5ton tractor, then a take off dump bed from the Forestry service (taken off to make it into a fire truck), then it's almost a total bolt on operation. I have done it twice and its very easy. You have to take off the 5th wheel and drill a few holes near the rear of the frame to mount the dump bed pivot. All the hydraulics ,pump and controls bolt right on!
Sent from my XT1080 using Tapatalk
Floridianson
2,487
Interlachen Fl.
I will say I love the system on the 817's. Dang bed goes straight up. The other thought was Santa lives in FL. The other thought was to many trucks sitting in a field that need love and to find a loving home some where else.
