5 Ton HET
porkysplace
1,496
mid- michigan
I will have to install an early warning system for swift trucks.
I'm thinking my bed space with the tractor might get limited.I will have 10 feet after the picker goes on to work with and I was thinking it would be nice to build a camper out of a 10ft sea can. I could overhang it a couple feet and have a club cab for a boot room.
Or keep it running at night.
61sleepercab
Walton, West Virginia
I consider Het1070 cabs as stub nosed COE style trucks because of the short nose and the tunnel in the cab. With HET nose there is not much hood to see. I get from your comment you are using the 5 ton tilt nose and a HET 1070 cab as a kind of crew cab. Are we now on the same page?
Carlstealth
Red Deer/Alberta
Yup I understand your point of view now. I never saw the HET as a COE before but now I do. I like the wind-shield configuration with the visor.I don't have a lot of room for a full crew cab so it will be a day cab with maybe a narrow bed and a small bench seat that can fold up so the front seat can slide back for leg room.My Buddy is building a Femmitt so I have to come up with a different plan and this works better for my purposes.
Carlstealth
Red Deer/Alberta
Everything will be water cut and formed and will all be on auto cad except the hand built areas like the floor structure bunk area.Have to finish up a tow truck deck then it starts.
Make some Blueprints or at least keep track of the dimensions you come up with.. It looks like it will be good looking truck.
Tornadogt
Adkins, Texas
From what it looks like to me is they used the original doors, door hinges and latches. then added there door skin to the outside... they made it pretty simple by making the windows fixed (will not roll down). Even with AC that would drive me nuts. How are you going to order from drive through at Jack in the Box.???? You could still use the doors and just make your own outer skins and better sealing moveable windows... maybe even Slider style windows like a RV or Boat?
A set of these mirrors would look pretty good..
http://www.steelsoldiers.com/showth...-large-Vehicle-Mirrors-w-bracket-and-hardware
Csm Davis
404
Hattiesburg, Mississippi
I scaled the cab using the tyres as reference though it looks like the HET cab is a little small (didn't shorten the sleeper either).... and no, I didn't find a RHD HET... Had to flip it to match the 5 ton.
Dang it Zebedee now I want that cab on my monster wrecker! Oh by the way guys the 102" cab will look fine over hemmet wheels and tires.
