5 ton injectors on a deuce motor?
Camoclad
Waterville PA
is there any chance of harming my relatively virgin motor with injectors. Have Pyro and boost gauge installed. Only Prob is that Im about as high on the injector pump as I want to go. Pre turbine temp is around 1000-1100 pulling hills. Boost pressure is a high 15psi although I don't totally believe my el cheapo chi com gauge. I do notice my truck has alot more power. Plan to put a stewart warner on to replace boost gauge. Thanks for your help. I hear you may know alittle about these trucks. Thanks Andy
Westech
CPL
6,104
207
cow farts, Wisconsin
you be ok as long as you keep the temp down to 1100* or so. That does seam a touch high in the PSI but not out of this world. You should be good to go .. just drive smart
oddnor
Drammen, Norway
The only Different's is on the nozzles is the holes, one ore to hole nozzles.
and some old types use shimming instead of screw to adjust the pressure.
If I'm not to wrong the LD and and the LDS have the same type. 2 hole
So you don't get mutch more power out of it.
But there is a way to get more out of the fuel and so more efficient use.
You have to adjust the nozzles up to a higher pressure , and so you get more out of the fuel.
And the nozzles are German M.A.N type so they are easy to find new
Odd
Floridianson
2,487
Interlachen Fl.
Odd
What is the higher pressure figure?
Could getting the pop off set higher cause any type of premature failure in the IP like O rings or such?
oddnor
Drammen, Norway
When I did mine I did ask the M.A.N work shop, and from a old man so have done the engine in a life time he told me to get it up to around 4700 psi.
You have to take the nozzles out and in a tester
The main problem with then are that needles hang up, and then they not work good.
You can see on the nozzle if they are good or not, if they are burned around the hole, they need work, when you take them out.
And in the tester if the spray angle in wrong
The needle is easy to change/fix. and cheep
Odd
